K so on the stock 02 660 clutch perch there are 2 extra black lines that connect on the actual perch. I think one was parking brake which I already eliminated and I'm left with one still there and idk whT it is. It just runs underneath to 2 diff wire connectors, I think one wire was black with yellow streek and other was straight black. It looks like it had a sensor for when you pulled the clutch lever in but I'm not sure any ideas. I'm adding asv levers which is why I ask
It's the starter interlock switch. Disables the starter when the quad is in gear and the clutch is not pulled.
Yep, just connect the two wires together and tape them up out of the way.
or just hook the bullet connectors together were they go into the main bundle.
