Talked to Partzilla today. They looked on their end of things and it shows that fender coming to them in the end of May. I am sure the ship that was stuck in the Suez didn't help things. Good thing these are just cosmetic parts, nothing I need to ride if I so choose to do so.My fenders from Partzilla that came a couple weeks ago were originally back ordered until late March, early April...then just suddenly showed up.
So, you guys may get lucky too.
Great bikes!! Talk something about the red Raptor, what mods it have on the engine performance staff?400 horsepower all cleaned up. Now raptor rally prep begins.
It’s a 795cc. 7mm stroker falicon crank, 105.5 bore, high compression, +2 stainless valve Cuervo head, 5250 cam, 54mm throttle body, monster exhaust, cryo treated and micro polished transmission, runs on e85.Great bikes!! Talk something about the red Raptor, what mods it have on the engine performance staff?
Sounds like a monster!! It should be very funny to ride a similar bike. How often you need to rebuild engine? It becomes like some sort of YFZ450R engine maintenance or not? ThxIt’s a 795cc. 7mm stroker falicon crank, 105.5 bore, high compression, +2 stainless valve Cuervo head, 5250 cam, 54mm throttle body, monster exhaust, cryo treated and micro polished transmission, runs on e85.
No reliability or early wear issues. Only real problem is chain maintenance. Have to clean/lube/tension chain pretty much every time I put fuel in it.Sounds like a monster!! It should be very funny to ride a similar bike. How often you need to rebuild engine? It becomes like some sort of YFZ450R engine maintenance or not? Thx
Good to know that. Too much power make the chain to come a bit loose after the ride? A stronger chain couldn't solve the issue?No reliability or early wear issues. Only real problem is chain maintenance. Have to clean/lube/tension chain pretty much every time I put fuel in it.
I’m running the strongest 520 chain that I know of. It’s not coming loose, just wearing quickly. Steel sprockets also last about 5 hours of ride time before worn too much for me. The horsepower and weight along with sand are brutal.Good to know that. Too much power make the chain to come a bit loose after the ride? A stronger chain couldn't solve the issue?
Will a 525 just not fit at the front sprocket or too much rotational mass?I’m running the strongest 520 chain that I know of. It’s not coming loose, just wearing quickly. Steel sprockets also last about 5 hours of ride time before worn too much for me. The horsepower and weight along with sand are brutal.
Not sure. I have a pile of barely used chains off the drag bikes, so doesn’t bother me to change them out often.Will a 525 just not fit at the front sprocket or too much rotational mass?
