1 - 20 of 36 Posts
pretty much what it says.....what all bends or Quad brand bars will clear the 700 gas tank, I got a set of Tag T2 CR High Bend off a YFZ and need to know if it will clear or not
thanks
I went with the Pro Taper SE Raptor bend. they look nice. havn't been riding yet. they look like they set a little high, but I still like the look.
I have Renthal 400ex bend bars on mine, looks like they were made for it :thumbsup:
I got the protaper SE raptor bars on both of ours. They clear and work rather well! Much better than stock
I think Pro Taper's "Raptor Bend" may be modeled after the 660 Raptor which is slightly taller. In my case that's a good thing.
i nned new bars asap due to mine are bent. but i cnt figure out which is best for my needs. im real simple . i want a direct fit similiar bend to stock that wont bend as easy. im thinking renthal or pro taper but not sure on which part # exactly. any help for a noob???ill most likely buy them for rocky mountain since i got 10% off my next order. any links? thanks
The only thing you need to really pay attenion to is the base width, height and over all width. The base width so the bars don't rub on the plastic unless you run a taller steering stem. And the remaining two for the cables, to wide and tall and the electrical will need to be moved.
I have a Gibson +1 stem with and anti vibe clamp w/ the T-2 CR bend bars. I have no issue with clearance. Everything works very well together. Something you may want to look into.
Frank
i just got 2 protaper se bars 1 for the 700 and the other for my 01 660. i hoipe they bolt right up and fit well. ill find out in the morning. i also got the spider grips to go along with them. anyone use the spider grips? will i run into any fitment issues? any tips?
This is a good thread. I'd love to see pics of the various setups.
I'm going to try Pro Taper's in a CR high bend, I think....As always I reserve the rite to change the plan.. :grin_nod:
Here are pics of my old and new bar set up.
Nice clean setup...What, no more parking brake ?? LOL :grin_nod:
Thanks man!! The hole in the Gibson set up is for the kill switch I'm installing tomorrow!! The parking brake was a pain in the ass. Also, take notice of the abscence of a certain Trail Tech computer!
Anyone try a narrower bar? I mean narrower in over all width that is?
I am use to a narrow bar on my PWC, and this stock bar just does not "feel" right to me.
Pro Tapers SE bars are narrower (30.3") than the stock bars (about 31"). Renthal has a Raptor 700 bend and a 660 bend. The 700 bend is about 31.1" wide. There is a difference between the 660 bend and the 700 bend.
Protaper SE Raptor Bend: "black" (ladies quad)
...weeellll, I have a pic but the upload folder is full.....
What grips have you gone with after changing out your bars?
1 - 20 of 36 Posts
