1 - 13 of 13 Posts
Just got back from Sand Mtn. Great time as usual.
My 2004 660 with port/polish, cam, Airbox, Yoshi with 22" Skat-tracs ran great.
Ran pretty close with some slightly mod'd 700s, real close. In fact, I was pulling on them late up the hill.
what can i do next without doing something over?
carb? I don't think the front sprocket was changed before I bought it?
I just want to get the 700s!
thanks in advance!
new piston and a big bore kit and LTE duals
boostman said:
sorry....686 kit installed too!
My 686 runs even the nicest 3 mod 700's into the ground. You shouldnt be having problems? I'd up it to a bigger bore/stroke and get a set of fcr 39mm's.
Gearing will make a HUGE difference in how fast you go up that hill or acrossed that sand, that'd be the first thing I mess with. If you're still using a stock length swingarm you're losing a couple lengths as well.
so down a tooth in the front? is that then a 15 tooth? is 16 stock?
longer swing arm? why
what length would I go to over stock?
thanks
thanks
13 is the stock front. A 12 makes a big difference and with your mod's shoudlnt bother your top end. I've ended up staying with the 14 even in the trails just suits my riding style better.
I have to drop to second pretty early on some of the hills.
I am 6'4" 240lbs so I am sure that makes a difference.
A buddy of mine, about 5'10" and 160lbs while riding my bike makes it up the hills in 3rd and 4th.
I have heard that every 10lbs of rider weight is equivelent to a hp.
so a 160lb rider on the same bike as a 240lb rider has 8 more hp.
So a 12 tooth should help me since most of my riding is on the dunes?
boostman said:
why does a longer swing arm help speed?
Keeps the front end on the dirt?
thanks
Essentially yes, you can launch harder and keep the front end down.
were you at sand mountasin nevada?
1 - 13 of 13 Posts
