1 - 18 of 18 Posts
THIS IS THE SPECS ON MY MOTOR:
2001 Yamaha Raptor 660 YFM660RN Motor. This excellent strong running motor has a Cylinder works 102mm 686 Big Bore kit with JE race gas piston, ported head with Kibblewhite valves, dual valve springs, billet retainers, and a Hot cam in it.
I WAS TOLD THE PISTON IS A 12.5:1 COMPRESSION. WHAT WOULD HAPPEN IF I RAN JUST 93 OCTANE IN IT??
THANKS FOR YOUR HELP???
Is this 100LL avgas ok to use in my bike?? My brother picked up 5 gallons of it and i want to make sure it will be fine. I see no reason that it wont but wanting to make sure
What cam is in it? stage 1,2 or 3? Find out you psi of the motor by using a compression calculator online and it will tell you. 93 is good for up to 225psi IIRC but I'm no expert by any means just what I have read on here.
do not use avation fuel in your quad. 12.5:1 should be around 93-96 r+m/2. but there are other factors that can change that.
mike
Because u have a raptor not a fighter jet hehe
Bump
What is wrong with airplane fuel 100ll????? Just trying to figure this out.
thanks
The octane rating with av gas does not compare to automotive style fuel...............
Yes, you'll be okay but it's probably overkill... you're right on the edge of 93 being okay all by itself - a 3/4 93, 1/4 110 (equals 97.25)would be a nice safe mix yet still overkill.
You have a similar setup to my bike. When I did my calculations a stage 2 hotcam was right on borderline for 93 and I would def blend. Stage 3 hotcam would give you a little more wiggle room and could probably run 93 but you should run the calculations for your bike yourself. I am running an x4 cam with a 12.5:1 and I think I could run 91-92 octane in a pinch but I run 93.
When I talked with Kenz after I had my raptor head setup to run a X-4 cam he recomended against running a 12.5:1 piston even with an x-4 cam. He said the shape of the raptors combustion chamber can cause detonation when running pump premium fuel.
thanks
It is designed to be burned at high altitude in a engine that runs at relitavly low rpm.
Dont I know that about detonation...........:)
Discussion Starter · #17 ·
ok so i am going to use a 3/4 to 1/4 ratio like quad suggested. Thanks for everybody's help on this issue!!!
thanks
its a very dry fuel meaning theres no lubercents meaning your burn a hole in your piston
made that mistake with a drag car ;)
1 - 18 of 18 Posts
