just got a new 700r and i was looking to trick it out i was looking at this set up lte's, pro flow, pclll, and 15t. that what i was lookin at. but i want to here your opinion of what i should get and how fast do you think i would go if i got what you suggested. thanks for your help
mabey its just me but i think ur on the right track the LTE's,programer, and intake even the 15 tooth sprocket.. :thumbsup: .but might need some better traction after all that...maxxis razr 2's one of my favorites...just tryin to help
If you have a new 07 model with a stock rear shock make sure you don't order the 2006 model LTEs like I did. If you do you'll have some clearance issues.
I just went from bone stock.... to having dual LTEs, Pro Flow intake, PCIII w/accelerater patch, and the highly recommended 15T primary. Haven't had a chance to ride it yet, but can't wait.
MONSTERMATT said:
accelerator patch?????
a mod you can do with the PCIII to make your fuel injector act as an accel pump, like on expensive carbs. Better throttle response :thumbsup:
I Suggest you get some good riding gear first, then some body armor, maybe a bumper, then by then youll need tires, so why not get some decent rims why your at it. After that its pretty much comes prefference on where you ride.
