1 - 9 of 9 Posts
i have a pro design pro flow kit and my filter is beat what kinds of filters will fit the aluminum adapter plate?
This first link will help you out if you want to put two filters insted of one, you have to match the size to your prodesign plate, and get it the right size to fit in the box with two of them. Get the number and go to a autozone, or parts store that deals with K&N and give then the number and they'll get you the filter. I think Coalshedracing can get them as well.
http://www.knfilters.com/search/univround.aspx
Heres the other shape filters if you want to try something else.
http://www.knfilters.com/search/universal.aspx
Some have optional outerwears or foam wrap that can be used on them, its usually at the bottom of the page on the individual filter you select.
will gytr air filters fit too?
GYTR's cotton gauze filters are supposedly made by K&N, not sure on the foam though.
But in any case, the pro-design adaptor is designed to work with either K&N or UNI. Just order a replacement filter of either type.
is the dual filter setup vs the one big filter more efficient?
Maddog56 said:
They'll make more power if that's what you're asking.
:thumbsup: thanks maddog
1 - 9 of 9 Posts
