I recently replaced the starter clutch on my 01. When we did, we had a few bolts that snapped off inside the rotor assy. So we put it back together with only four bolts for now. My question is whats a better name to look under for this part on ebay? Its #2 in this pic.
I cant find anything on Ebay under rotor assy? Second question would be, anyone have a used one for sale? Thanks DJ
Yamaha calls it a rotor assembly. Part #5LP-81450-00-00.
Flywheel. The bolts commonly break off in it, and can be removed by drilling, for example. When drilling with an undersized bit, they will usually turn out of the other side of the hole.
I suggest you put all the bolts in...............
