1 - 14 of 14 Posts
Whats the difference from the Alba 5th gear overide harness and just unplugung your harness?
It is the same as unplugging your speed sensor. Only benifit is it would keep your connections clean.
dont waste your cash on that junk... unplug it or make a cut out switch...
If you just unplug it, Be ready to see your engine light on. I'd love some ideas on wiring in a cut-out. :)
If you use the alba crap be ready to see your engine light come on as well. Iroc and others have posted their cut-out switches already.
It probably be pretty easy. You can buy those universal swtiches at any hardware store that cut power. I have one being used with my stereo in my car. Im sure it be a pretty easy task.
Hey pile
havent seen that post on the switches red the ones on Mikes Plug sounds good , but has someone fix the light problem ?
any info would be good ;)
Allways the last to know down here in Australia
yeah i second that, not much happens our way either does it
Ben
1 - 14 of 14 Posts
