I'm 6' 195lbs. I want to race XC and do a lot of recreational riding. Stock rear shock, YFZ front shocks, +2 +1 a-arms, stock rear swinger but flipped bracket and LSR Axle.
Ok, so now you know the nitty gritty:
The front sits at 47". What should I adjust the rear to? Right now it's at 45.5".
And, I downloaded an article that says your preload should be set so your rear settles 30% of travel and the front 20% when you're sitting on it. Do you guys agree with that?
And where is a good starting point for the rebound and compression adjustments on the rear shock and the YFZ front shocks?
I just got done setting mine with the 30% rear sag and 20% front. I guess the best thing to do since this is "just" the base line is to go for a ride and feel it out and go from there. I weight 230 lbs, (getting old & fat) but I like a somewhat "cush" ride nowadays :p My best advice to you is to ride and experiment with your settings, everybody has different tastes in how their suspension should or shouldn't work...
you'd benifit from stiffer springs for your weight. these shocks are designed for the 150lb rider (who in America weighs 150lbs...not me)thats why they sell aftermarket shocks/resprings built for your weight range to make the most effective use of the shock stroke. My rear of the frame sits 1 inch lower than the front.
