1 - 2 of 2 Posts
I got all new inner and outter bearings and oil seals for the front wheel hub but I cant seem to get the old bearings out which are mangled. Theres like this lip thats preventing the bearings from exiting. Can anyone explain from experience how to do this or a certain way? Also, I replaced the sprocket as the OEM was worn out, and on the OEM there was this gasket just as big as the sprocket going around it but was cracked up. Just wondering if I need a new gasket to put the replacement sprocket on or just bolt the sprocket on?
For the wheel bearings there shouldn't be a lip. To get the outer bearing out you pound on it from the inner side. Same for the inner bearing pound on it from the outer side. If you heat it up with a torch then let it cool they should drop right out. Mine did. As for the gasket. I know there is a seal behind the sprocket but I don't know of what you are talking about.
1 - 2 of 2 Posts
