I recently changed the oil in my 2020 raptor and the oil keeps reading empty on the dip stick am I suppose to check it when hot or cold
It’s almost impossible to get an accurate reading on a dry sump system like the raptor has. The best way to do it is to drain the engine & tank, change filter, and add a total of 2qts to the system. Then don’t worry about it until it’s time to change the oil again
Unless you have leaks, or your quad burns a ton of oil, the level should stay the same
Actually if you follow the manual pretty easy to check oil. Without a manual pretty frustrating
Reactions: Sixpack577
