1 - 11 of 11 Posts
Can anyone give me there views on which make valves to order,on ebay they have wiseco or kibblewhite,i am installing a 11:1piston,stage 2 cam and heavy duty springs and whilst the heads off i may as well chuck in new valves ,thanks julian:)
Or should i just get genuine ones?
Are you still on the stock rod ?
Kibblewhite
fererea valves are also a racers choice.
Ferrea valves are in my Raptor and Rhino...............
Ferrea because they are stamped one piece valves. kibble whites are made up of two different metals. The heads are one kind and the stems are another. They are then fused together or supose to be. They had a bad run that caused some probelms for people. I ran a set of standard ones but when I went to +1mm valves I went with Ferrea.
thanks guys ive got a set of new stock ones coming,maybe next time i might splash out on the ferreas,cheers julian
Sock valves are soft and the heads cup. That is why you have to adjust them more. Even more so when your running stiffer springs for a stage 2 cam and up.
1 - 11 of 11 Posts
