1 - 13 of 13 Posts
while im riding randomly the red reverse light goes on and the engine begins to bog down. I have no idea what is going on! could it be electrical, terminals to batteries, carbs? PLEASE HELP!!!
02 raptor 660
my whole parking brake assembly is off the quad, when i bought the quad it didnt have one the assembly and cables were removed.. so i dont have a parking break.. when i ride its usually works great in the begining. Into the ride it will randomly bogg and red light comes on. unexpectedly.
just ground your reverse switch that will fix the problem man
i belive it is the blue white wire that is coming up from by your shifter on the engine there is a plug just take taht wire and ground it
well they are all the same its the stripped one lol
I wen back to look at it and try to fix it, i looked next to the shifter below the nuetral light wire, i found where the wires for the reserse are supposed to go but i didnt find any wires connected. I looked under where the reverse knob, ( switch/lever) and there is a lot of electrical wire wrapped around where the wire come out. looks like the previous owner played around with the wires
try and trace it up and fine were it plugs into the glolor of plugs by your left knee there a more plages up there to ground to back track a litle then ground the sucker lol rember its the stripped one nnot sure what the other is
The reverse wiring doesn't go to the switch/lever, only to the post comming out of the trans case and back to the cdi. Green wire with a white tracer/stripe.
The head lights work, first thing that comes to mind in the reverse lever area.
1 - 13 of 13 Posts
