RaptorFreeeek said:
I take it in every 20 hrs. They change oil, check spark plug gap (change spark plug if needed) check tire pressure, adjust, clean and lube chain, measure and adjust valves accordingly, wash quad. Clean air filter. check tension in all cables. But, I've been told that not all dealerships go to these great lengths either. Guess I just got luck with my dealer, and they have great customer service!
Not to rain on your parade, but paying $150 every 20 hours for service is quite expensive.
Oil filter = $10 max
Oil 2 quarts (amsoil) = $15 max
That's $25 tops.
Checking valves with a feeler guage is no big deal and the other stuff is just cleaning which should be done after every ride anyway.
Buy the scotts oil ilter for $60 and you'll never need a oil filter again.
Do the maintenance yourself if you can turn a wrench. :thumbsup:
