Halls, ive been told I need a rising rate fuel psi regulator, larger injector and a 2 bar map sensor. I need to take a long look at the 700s fuel system and see if one of these regulators can be adapted. Ive found 3 or 4 universal ones on the net. I havent found any injectors thus far....Denso has been no help. Ive emailed Denso of Japan. They told me to contact Denso of USA> I contacted them, and they have not recieved a response.
I contaced turbokits .com and they said if I send them the injector, they can find a larger one to match or increase the flow of my injector.
In regards to the R1 swap, Yes I have thought about it, but that motor will weigh a ton more than a 700 turbo> I want a dual purpose bike to hit the whoops, drag the hills, and play dune with the group. A properly tuned 700 turbo will work better for my application. I think the R1 swap is an excellent drag bike setup.
