1 - 13 of 13 Posts
Does everything bolt right up? I've heard that some of the bolt holes are different.
I should be able to just buy a subframe and stick it onto the 2001 frame, right?
2001 frame +2002+ subframe = okay to powdercoat 2005 frame? Is my logic correct?
Thanks Guys! I cant wait to show you the official.
This is the powdercoat color: http://www.prismaticpowders.com/colors/PMB-5043/
Yes, you are perfectly fine to powdercoat your 2005 subframe. Looking forward to seeing it done! What color plastics are you going with to go with the copper frame?
where does the rear shock resi mount at on those frames?
^ yeah i was asking about the 2001. shoulda been more specific..
Discussion Starter · #13 · (Edited)
how much are they getting for powder coat out there , including sand blast?
The complete powdercoat. ie Frame, A-Arms, Rear Grab Bar and Nerf Bars is $275-300. It depends on the exact color I go with.
Does anyone know if the voltage regulator has a easy place to mount nearby?
1 - 13 of 13 Posts
