its a standard axle
will it fit my raptor 660?
I have a spacer from my g force axle that I ordered. It was needed if I was installing on a blaster, but since it went on my 660 its just laying around. Mad dog, if he had that spacer would he be able to use the blaster axle? If so you can have it.its a standard axle
Would i have to do anything special or does the banshee axle just go right in?Perhaps he bent his 660 axle and found a cheap or free blaster axle, and wanted to know if he could use that instead.
Raptor 660 owners sometimes put stock banshee axles and often aftermarket banshee axles on their atvs because they are wider than the stock 660 axle.
Are the hubs the same?Banshee axle goes in, just the other way around. You use Raptor OEM brake and sprocket hubs. Been so long since I played with stock, can't recall what the axle nut situation is.
Thanks Mad Dog for your help. I just picked up a almost new axle for 20.Blaster/warrior/raptor350/yfz450/Raptor660/Raptor700R rear hubs are interchangeable, but the blaster has a different bolt pattern.
