1 - 10 of 10 Posts
I have an 2004 660r that I purchased, i’m getting nothing when I try to start it using the button. If I put a jumper on the relay it will crank but not run. Any help is appreciated
Hey so maybe you need a battery and or relay I had that problem i changed both and no problem with the button start up
Sent from my SM-G950U using Tapatalk
Discussion Starter #3
The battery is new but I do have a relay being delivered today I’ll let you know if that solved it
If it's cranking, but not starting, pull the sparkplug and make sure it's firing, or if it's wet/getting fuel.
Welcome to the forum!
Do you have 12V at the yellow/black wire on the relay both with the start button NOT pressed and pressed?
If so, does the blue/black wire have 12V when not pressed, but 0V when pressed?
Discussion Starter #7
Did some reconnections and yellow/black 12v presses & not pressed. Blue/black 12v presses and not pressed
Okay, great!
So, the start button simply shorts the blue/black wire to ground when pressed. Since your;s is not going to 0V with start button pushed then either your button is dirty/corroded internally or the blue/black wire is broken or disconnected somewhere between the relay and the switch.
Try briefly jumpering the blue/black wire to ground (use a straight pin to pierce the wire) near the CDI and your relay should close and the starter turn - then try the same near the button - if it starts then the button is at fault. if not it's the wire.
Let us know your results.
Glad to help.
1 - 10 of 10 Posts
