Have you recently done anything to the bike, what are you mods and jetting...................2006 raptor 350, starts good, idles good. cuts out above 1/4 throttle.
Not sure if the Raptor 350 is different then the Warrior, but I do know that the Warrior had some kind of rev limiter built into the reverse lever somehow.............350 doesn't have any rev limiters at all. These engines will rev to the moon if you don't let off the throttle when they get real high up in the revs, nothing to cut it off..
you sure? I remember one time backing out my buddies warrior i couldn't find the rev limiter, and i had her pinned in 2nd going down the road and there was no rev limiter there either. I know the warrior did have the parking brake rev limiter like the 660 has, but the raptor 350 has the newer style parking brake so it doesn't have that cutting off at low rpms when you try to rev it.Not sure if the Raptor 350 is different then the Warrior, but I do know that the Warrior had some kind of rev limiter built into the reverse lever somehow.............
Start a new thread with this and then we can help with the issues that are affecting yours.I have a I have a Yamaha Wolverine it's a 2005 or 2006 and I had to change the wiring harness cuz it was all burnt up and I have the low RPM problem we're all at once to do is idle and you can barely give it any throttle than anything after that it'll try to cut off her. And it doesn't have a reverse switch the only thing it has is a clutch safety start switch
