SO - when you short across the two large lugs on the starter relay NOTHING happens? No sparks, no starter motor turning, no noise, nada... and the lights (neutral and headlights) stay lit while doing this?
If so, and you haven't left anything pertinent out of the symptoms, then either the starter is bad or the cable leading from relay to starter is bad - period.
