1 - 10 of 10 Posts
My 02' 660 won't shift out of neutral into 1st gear, but if will shift into any other gear just fine. Is it a broken gear? Any help would be much appreciated.
i haven had that problem yet. but there should be someone to help you on this site. if not go to your local yamaha dealer and ask them.
Is your shift lever hitting something before it can shift all the way down?
Have you tried adjusting the shift linkage?
Does the clutch work properly?
Clutch cable feels like there is nothing to it. I took it off of where it connects to the arm that goes inside the case and the cable is fine it pulls fine and feels smooth. Nothing is in the way of the shift linkage.
Try shifting while pulling the cable. Maybe your lever is way out of adjustment?
I've tried adjusting the lever no luck and yes it happens all the time. I can get it to go in if I let almost all the way out of the clutch and push down really hard on the shifter.
1 - 10 of 10 Posts
