Bought quad. Put battery in Turned key on and tried button the temp light comes on with one solenoid. The other that came with it I tried and It Just Cranks and cranks. Try starting fluid and it backfires slightly. It Did push start a few times when we brought it home. Please please help. Can I just order new carbs . it has spark just put new one in and tried it. Help
You might check the valve adjustment. If the valves are too tight it won't run. I had a couple of 400 Suzukis that would do the same thing when the valves got too tight. You could push start them but they wouldn't start cold by the starter even with starting fluid.
Yes, valves get tight as they wear making cold starting difficult... check clearance.
