1 - 10 of 10 Posts
My 05 Raptor 660 will not start. I had been riding for about an hour and then i stopped and it just cut off. I tried restarting in immediately but nothing. The lights wouldnt come on and i made sure all the battery terrminals were connected good. All it would do is i could here a click from under the seat. But i had my friend pull me and i dropped it in first and it started like that. So idk if its battery or someone told me posssible the one way bearing??
HELP!! :wow:
Git-R-Done
It sounds like your starter relay might be bad.
Thank You. Im going to put a battery booster on there today and make sure its not the battery. So if that doesnt work then ill look into the starter relay!
Git-R-Done
Welcome to the forum!!!!! Try to short across the two large lugs on the relay with a screwdriver or pair of pliers (ignore the sparks). Does the starter turn over now? if it does then i would replace the starter relay.
if it doesn't it might be the brushes in your starter. LIGHTLY tape the starter with a hammer while holding the start button. if it starts that way you need new brushes
If your lights also wouldn't come on, it's battery, battery connections or fuse related (could be key switch also).
If it starts with a battery box, it's most likely battery... but clean the battery connections anyway.
I believe it is the battery, that happened to mine and I jump started it and it crunk right up.
o and since it cut off and the battery was dead, it could be your recifier, check that too!
Hahahahaha I'm sorry, I don't mean to laugh, but this had me rolling for some reason. "Jump started it and it..." DID WHAT?
Thanks guys! It was the battery, i got a jump box and it fired right up. Preciate the help!
1 - 10 of 10 Posts
