Not really a problem but rather curosity. So my raptor blew a head gasket after rebuild :(. havent had the time or money to get a new one but iv found one that i got with a kit awile back but the problem is its for the standard bore. mine is bored to a 686 im pretty sure thats 102mm but i see they sell 102mm head gaskets on ebay would it really matter if i put the head gasket i found on or will i be better off buying a 102mm one??
The OEM and cometic gaskets I've used work for anything from 100mm-102mm. I would look up the part number on the kit, call the manufacturer, and ask.
Measure the bore size of the head gasket. If it is at least 102 to 102.5mm, you are okay to use it.
