i have 06 yfz shocks on my 06 raptor..... problem is they bottom out everynow and then. i have noticed that when i unload my front suspension my shocks go all the way out. for instance i can pick up the front of the raptor and my shocks droop until they are all the way out. i checked other raptors and yfzs front susp. and they droop less then an inch when unloaded.
my question is how do i fix my problem. ive tried adjusting the rebound and compression , but i dont see that fixing this problem. any suggestions.
thank you ryan
sounds like preload and spring rate to me
cool thank yall for the replies.... ive already tightned down the spring some , is there any way to get both shocks the same other then counting the exposed threads??
i bought them off ebay so i dont know if someone has altered them already.
Easiest is to just thread count. Or start all the way from the top and mark it and count how many times it makes a full turn. Or you can measure from top thread down to the preload nut.
