You want your ride height between 8 and 10 inches. You measure the front from the ground to the front motor mount and measure the rear to the bottom of the foot peg. You usually want your front measurement to be at least an inch higher in the front. So if you're running 8 in the rear, you want nine in the front. If you're running nine in the rear you want 10 in the front.
Frank
Frank
