Cleaning a Raptor 700 under the seat
1.9K views 6 replies 7 participants last post by  D13
#1 ·
Hey everybody...
So ive never had a brand new machine...im looking to take care of this thing though now that i do...
My first ride was in an insane mud put and i have mud CAKED under the seat...i was going to try using a cloth but there is just too much...can i hose it down under there or will it really present issues? The battery seems to be covered prettt well with that rubber piece but there are other electrical connectors and of course the fuse box...anyone hose under there before? Any recommendations on how to get this clean?
Thanks in advance
#2 ·
Cover electrical with plastic, hose off the rest. If you can cover any connectors that would also be wise.
Reactions: Alamo
#3 · (Edited)
I don't use pressure when washing its near delicate stuff or when water could go into places I don't want it to go. Try to avoid the connectors whenever possible and you should be fine.
#4 ·
When you splash thru a water hole everything gets wet, so using a water hose isn't much different. To insure water doesn't get in electrical connections I always squirt some dielectric compound in each connection including the fuses, and any wire under a bolt like at the starter relay.
#6 ·
Get yourself a 1 gallon pump sprayer from walmart or amazon, and fill it with your favorite degreaser (simplegreen, purple power, etc...). I actually use Tide laundry detergent. For whatever reason, it really works well on aluminum, plastic, and painted surfaces. Lifts dirt right up. I've been doing this forever! I even use it on cars too, wheel wells, under the hood, etc...
If its really bad, you should use a pressure washer. I like the electric ones as they are around 1200 PSI vs. a 3500PSI gas pressure washer. Just do your best to not directly hit any connectors, electrical components, or seals (bearings, clutch arm seal, etc...)
