Hello everyone!
I have been lurking around here as a guest for some time while fixing my Raptor, however the time has come for me to concede defeat and reach out for help:
I was riding a couple months back when all of a sudden I lost all pressure in the rear brake. Figuring it was seals in the [master cylinder?] I purchased a rebuild kit with new seals, new spring, new dust cover. I put it together, installed, and bled, but it still has zero pressure when I push on the brake. It goes all the way down and the pad does not contact the rotor. I tried manual bleeding as well as using a vacuum bleeder to pull the fluid out of the bleed screw. Any ideas as to what the culprit is?
