YFZ 450R SUSPENSION!!! help needed!
1 reading
10K views 4 replies 5 participants last post by  BANZAI7
#1 ·
do you think these would work on a yfz450r with stock a-arms?
Description:
Works Performance Part Number YA-3444
Fits a Yamaha YFZ450 2004 and later model years.
These are a front pair of Piggyback series shocks. These shocks are 15.75 inch long shock length (eye to eye). These shocks have powdercoat red, white and black Triple-Rate Spring set. Factory pre-set for 161-210 lb Motocross riding, or 211-250 lbs recreational use when used on stock a-arms. These shocks are adjustable spring pre-load tension (to adjust rider sag or to prevent bottoming). The rebound and compression damping are set internally, not adjustable by rider, for the specific application, terrain and rider weight.
#2 ·
I'm guessing that these are stock travel ? I have these in Long Travel on my raptor, they fit my houser a-arms, works shocks asked me what a-arms I was using to make sure that the shocks would fit the lower mount, that would be my only concern with these for you, measure your lower shock mount width and just double check that with works shocks, i'm sure it will be fine. great shocks !
