2003 660 raptor
1K views 5 replies 3 participants last post by  QuadManiac
#1 ·
I have a 2003 660 raptor it turns over but won't start and I have spark, I cleaned tf outta the carb it's getting fuel. But will not start unless I bump start it and it runs good even at idle
#2 ·
Whats the battery voltage when cranking?
#3 ·
This is a common issue if the intake valves are tight - check your clearance. It will cause poor start unless you bump it.
The valves tighten up as they wear, and when cold the clearance gets closer than when hot - so you can ride it and its fine, but once it cools down it won't start cause the starter can't turn it fast enough to build up compression.
#6 ·
I've told you what the most common cause of your exact symptoms is... it could be many things including the convergence of Venus and Mars - but since they are MUCH less likely to be your issue, I have not included them in my suggestions. ;-}
