Rebuilt water pump but still leaking through...
2.4K views 5 replies 5 participants last post by  jesse
#1 ·
I rebuilt my water pump with all new gaskets, impellar, seals and its still leaking trough the little seep hole at the bottom of the casing :help:
#2 ·
First question, is it leaking oil or coolant?
I'm assuming you also replaced the seal that is pressed into the casing? The one with the little spring is what I'm referring to.
#3 ·
yes Mad Dog, I replace both large O rings, Impellar, White plastic bushing that goes inside impellar, bearing seal, and the mechanical seal that is pressed into the casing.(which by he way was a mission to take it out. ) The only thing that I was not sure of was the bearing seal, I am not sure which wait was supposed to go in, it kinda fell out as i was removing the impellar so i didnt get to see which way it belonged.
It is leaking coolant... not oil
