61 - 80 of 123 Posts
Hello friends, I tell them I'm from Argentina ... I have a raptor 700 with GYTR exhaust, GYTR air filter and Efi Controller Trinity Stage IV. What I would like to know how to configure the controller for best performance ...
Of course I thank you and congratulate you on the forum!
Escuchar
Leer fonéticamente
Still not many for duals yet.... Im after some settings for DMC controler, DMC force 4's and prodesign intake w/K&N filter and EHS lid... but if yours has no lid it will do fine also! thanks guys!
Anyone have settings forDmc duals, pro design air filter with lid off? I have a dmc fuel control module for it...it's for a 2006 raptor 700.
My setup is similar to that, dual barkers, prodesign intake and lid off. I also have a 11:1 piston and HC2 cam but I don't think they would change much? I'll check my settings tonight and report back :)
I have the newer dobeck though, with 5 pots.
thanks qcraptor! I have the DMC EFI, 5 pots also! I heard its set up for my dmc twins and pro design but im keen to see other guys settings for similar!
my set up on my wifes rappy is DMC single full system mod quad intake with k&n no air box settings on my controller its a attitude industy g2 y3.5 r 3 yb4.5 rb4.5 plug is a little carboned but the rappys like to be a touch rich
Here:
Green: 1.0
Yellow: 2.5
Red: 3.5
4th: 5
5th: 3
Sorry if it took so long. Spark plug is perfect with this setup and I have no issues with the bike, runs like a champ!
(07 Raptor 700) Would anyone know how installing a HC2 would effect the settings on my DMC EFI Controller. I have dual DMC afterburners and K&N Filter with an intake system and open lid. Would I need to richen it up or make it leaner??? Trying not to have to switch to a PC3 seeing as this is the only internal work I will be doing for a while.
Thanks!
Dobeck settings
I need the settings for a dobeck gen 3. DMC controller actually. I have dmc force 4 duals, Pro design intake with KnN, stock tb with a stage 1 port and polish on head, 11.1 piston with spark plug mod. Pm me with your settings...Thanks guys
anyone
i need one also for trinity controller gen3
mods:lid on,11:1 cp,stock exhaust s/a out,hc2
i just plugged it in and went so i dont know if its good or not. runs fine
The best recommendation I can give is to contact the company who's name is on your box. Every company that badges their own name on a Dobeck controller has a different map; unless they have the Dobeck factory installed example map. In order to know where to set your controller you need to know the range of fuel % increase and how large the operating window is. If they do not have enough % of fuel increase, or the load vs rpm graph was not set correctly you may need a new base map and that can be a pain the arse seeing as how all companies maps are propriatory and must be unlocked to remap. When purchasing a Dobeck style controller it is important to check with the company who mapped it to see if they have multiple maps for different setups...This thread should have sub sections for each individual company since that is the only way you can share settings safely.
Nate
Alba Racing
shoot its a lexx gen 3 so ill have to call them. how do i get it remapped? is it easier to get a pc3?
I usually contact the company and ask if they have alternate maps. If they dont, I ask them to give Dobeck permission to unlock the box for a 1hour window and I install my map. A tuning session on the dyno is the best answer, but a few rides and adjustments is usually all that is needed for basic setups. The PC vs Dobeck discussion can go on until we are all blue in our faces, regardless what you have already should be able to support any fueling demands you have. With a lid on I cant imagine you running lean. Are you getting any backfiring under decel?
Nate
Alba Racing
no not at all it runs great actually i havent checked the plug at all yet but other than that it runs good. idk if its at optimal performance but it probably could be. all the ones ive read noone really had the same as i did (11:1 piston,hc2) i think i stopped at page 7 and only seen one with the close to the same setup hc2 11:1 je, exhaust and intake i think.
it would be really nice to get it set up. can i get a map from them? i noticed that its not a usb plug in
i would like to run it without the lid but when i was on the trail they had a ton of rain and couldent
You can't remap it yourself. There is a docking station for gen3 units that plugs into the socket behind the rubber plug on the back. Newer gen3.5 units uses an infrared beam to reflash the module. You can buy a docking station, but would have to get the company to add you as a tuner to their account. Tons of my dealers have them, but I am rare in the community and encourage my dealers to learn them.
Nate
can u give me an estimate of what it costs to have it tuned?
