how much oil??
5.9K views 7 replies 6 participants last post by  Hooligan
#1 ·
how much oil goes in yfz 450???? 2008!
#2 ·
It'll end up being just shy of 2 quarts with filter change.
#6 ·
That would mean you should put a little LESS than the spec amount, due to residual oil covering parts, internals, oil lines, etc.
Spec states something like .8 in the case and 1.2 in the reservoir. Just under those amounts w/ filter change and you should be good. I had problems running mine with too much oil before, so use less, measure it, then add more if needed.
#7 ·
1.96L is 2.07qts. So there is more then .07qts left inside the engine and reservoir. If you can measure that to add to your case then good on ya, but .07 isn't very much oil at all.
So you're correct I was thinking 2L not 2qts. Sorry. But any way to stack it 2 of either measurement will be enough. Remember there is a cross hatch section. So you could be under/on the full line or over/on the full line.
